RCU Forums - View Single Post - Aviation Designs "StarJet"
Old 09-06-2003 | 02:56 AM
Mokulele
My Feedback: (9)
Default Starjet
David,
This is what I got from Aviation Design:
aileron up 12mm down 12mm
elevator up 15mm down 15mm
flaps 0 mm up, 75mm down with 15mm up for the aileron as a cro brakes effect + 5mm down elevator for pitch moment.
CG is 20 inches or 510mm back from the front point along the leading edge of the wing.
You must remove all air bubbles from the plasma bags. It may run okay on the ground but as soon as your jet gets a high enough angle of attack that bubble will get sucked into the fuel feed line and your engine will probably flame out.
Larry
