RCU Forums - View Single Post - Evolution .52 Engine
Old 08-07-2012 | 04:54 AM
jester_s1
Moderator
Default RE: Evolution .52 Engine
If your screws were loctited, they likely didn't vibrate loose but just wound up loose when the gasket compressed. There's nothing wrong with using a gasket, but you do have to understand that it will compress a bit in the first run or two. The remedy is to not loctite the bolts so that you can retighten them after the first run and again after a couple more runs.
