RE: McCoy 35 Carb Venturi Insert
If this is the series with the two lightening bolts on the engine, they had inserts. These can be removed if the fuel tank was located well. I have run mine with the insert removed and they ran fine doing loops and junk. I have a .19 that will not run with the insert removed unless I use muffler pressure.
