RCU Forums - View Single Post - Good Starter Plane
Old 08-07-2012 | 05:48 PM
GoBeach75's Avatar
GoBeach75
Default RE: Good Starter Plane
<div>YT,</div><div></div>I would suggest getting a small powered glider. Learning to fly on a powered glider will make you a better pilot in the long run. Gliders force you to learn about how wind affects your flight and using the air to your advantage, but because it is still powered if you get into trouble you can get out of pretty easily.<div></div><div>My suggestion is the Hobby People Superfly X RTF Glider Here is the link: http://www.hobbypeople.net/index.php...mhz-radio.html</div><div></div><div>It is a great starter plane because its a glider, it is pretty durable and you can fly around at a good sized park. Plus if you do crash it or break it you can get all of the replacement parts for it.</div><div>http://www.hobbypeople.net/index.php...9&amp;cat=3002</div><div></div><div></div>
