ORIGINAL: GraemeEllis
[edit] Flew the model three times, no issue. In fact, I it seemed to be climbing a bit at half throttle like a flat bottomed model should. No water in the elevator this time - it was easy to check because I covered the bottom with transparent film this time! </div><div> </div>
Great to hear, if the symptoms did not return, then it is a good chance that the problem was some water getting in someplace, but you probably got that fixed.
Enjoy the water while it is still liquid ))
