RE: OS BGX-1 Glow to Gas Conversion (Yeah!) Thanks Max
Sorry to be so obtuse, I'm trying to get this right.
You said: "In your picture, the screw is horizontal looking at the front of the engine. He wants the screw to be vertical looking at the front of the engine. "
But before then you also said "the sensor will end up being at around 3 o'clock or so looking at the front of the engine. "
Did you mean "the TAB will end up being at around the 3 o'clock or so looking at the front of the engine"?
If I rotate the sensor to the 3 o'clock then the screw is not vertical, instead it is moved to around the 7-8 o'clock+ position and at an angle.
