RE: NEW DLE 20cc Gasser! (Data & Links 1st Post)
I have read through the forum as time has permitted and have used the search function, but I still am not certain on the correct answer.
I want to go to to a LIFE 6.6v battery. Have any of you run this type of battery with any luck or bad luck? I am afraid of burning up the electronic ignition. I was looking at the cost to replace the ignition if I should happen to burn it up, and $85 versus $22 to me is a no brainer. I know that nicd and nimh coming off the charger at at a higher voltage than 6.6v, but they do drop quickly. I would appreciate a little more insight and experiences if you have them. Thanks,
Shannon
