RCU Forums - View Single Post - DLE 20cc Gasser! (Data & Links 1st Post)
Old 08-08-2012 | 11:21 PM
  #5656
aerobear
Default RE: NEW DLE 20cc Gasser! (Data & Links 1st Post)
From all reports this is a great product backed up with great service.
On the other hand, for the $45 purchase price you could instead get about 1400 of [link=http://www.mouser.com/ProductDetail/Fairchild-Semiconductor/1N4007/?qs=ZbYWOjW8mGpgsSEErKxdmfUH0OoFY7oB]these[/link]. That's enough to equip 700 planes with a ignition voltage reducer suitable for LIFE type batteries. If you only need enough for a few planes then your local electronics shop can set you up for a buck or two. Using these with a separate ignition battery will increase your plane's weight by a few ounces over the Ultra IBEC. If that's a problem then there are usually other, cheaper ways to save that much weight.
Nothing wrong with either choice, just letting you know there are choices.
