RCU Forums - View Single Post - over heated engine
Old 08-09-2012 | 06:47 AM
SeamusG's Avatar
SeamusG
Default RE: over heated engine
Very easy to determine if piston / line damage has occurred. With the OS91FX it is a simple task to remove the head - 6 hex head bolts. Do it while the engine is still in the air frame with the prop mounted so that you can turn the crank using the prop as a handle.
