RCU Forums - View Single Post - Sig kit
Thread: Sig kit
Old 08-09-2012 | 02:39 PM
N1EDM
Default RE: Sig kit
If you are using a 4-Stroke, keep in mind where the throttle is so that you can cut a hole for the pushrod in the correct location. It won't be like a 2-Stroke. Most folks use a reverse curve for that or a dubro 4-Stroke throttle gizmo. Have you seen those or do you need a picture of a typical setup???
Bob
