RCU Forums - View Single Post - How do you tune a 3W-100
Old 09-06-2003 | 11:33 AM
Diablo-RCU
Default How do you tune a 3W-100
If the engine changes the way it runs and the weather is constant, then something else is changing. Check everything inside the fuel tank and all the lines, the carb mounting bolts, the reed block bolts. Mike Glavin e-mailed me that some of the 106 motors have an ignition that gets inconsistent in the heat. Talk to the distributor - maybe you need a replacement ignition.
