RE: flybar help
if you look from the end of the paddle twords the head you want your paddle to be as perfectly inline with the cage as possible and you also want to make sure the bar itself is has the same amount of distance from the end of it to where it enters the cage on both sides then after your put the paddles on the measurement between the cage and the paddle (inner or outer) is the same distance.
