RCU Forums - View Single Post - Amp Draw on servos???
Old 08-10-2012 | 02:42 PM
Jetfan20
My Feedback: (21)
Default Amp Draw on servos???
Hi All,
I'm getting .10 amps on my flap servos at neutral, when they are deployed in motion a little higher but once they get set i'm getting about .05 amps. Is this Ok? Then when I pull the flaps back to nuetral my amps no longer settle at .10 it's around .14amps. Is there any need to be concerned about these numbers? It's setup on a 1/4.5 Hawk from Fly Eagle Jets and the flaps are pretty big, the servos are Hitec 7955. What kind of amp draws are you guys seeing?
Thanks Again for all the help!
