Yup, mounted the Himax directly through the firewall Pletty 3-hole pattern with
the EF supplied spacers. Needed slightly longer bolts than supplied with the Himax, got those at Lowe's. The rest of the hardware came with the motor. Works fine, check the bolts every few flights, easy.
