RE: 120 decreasing rpm
I just realized that the pressure port cant put out fuel or when I would vent the fuel system fuel would come out instead of air like it is. I also failed to mention that I have the regulator screw backed out about 1/2 turn. I also meant to add that it will run great with the high end needle turned in all the way.
thanks
Jeff
