Hello,
Thank you for the advice! So I wouldn't have to re-drill two of the mouting holes, instead of that just keep trimming as close as possible? Are you using the supplied grommets and eyelets?
Thank you!
Kind regards,
Nickolay
ORIGINAL: RC Accessory
I also have the S9650's in the tail. You will have to remove some of the ply mount to where the servo screws would be, maybe 2-2.5mm. Just keep trimming until you can get them in. It took me about an hour for the first one and then about 20 minutes for the second one. Also, if you use the Dubro servo arms, you will have to trim the opening. I elected to use metal servo arms that I already had which are much thinner than the Dubro arms. I have the Dubro arms on all other servo's.
