Sounds good, did you strip the spur at the end? When the clutch bell gets hot and you let it sit for a bit, the heat will transfer into a couple spur teeth and makes them soft. Then when you hammer it there is a chance that you can peel those heated teeth off along with the rest once the ball gets rolling.
