RCU Forums - View Single Post - gas/glow conversion fuel mix question.
Old 08-13-2012 | 09:46 AM
av8tor1977's Avatar
av8tor1977
Default RE: gas/glow conversion fuel mix question.
Instead of just tightening it up, which would be the normal tendency, you might want to take it off, check the gasket, and sand the insulator block on a nice flat surface to make sure it is still straight. (And/or make it straight if it is warped.)
Note that fixing this leak is going to change your mixture tune again....
AV8T0R
