RE: PA Addiction X??
I'm usinga countdown timer set for 10 minutes and landing with 3.6 - 3.7 / cell. That's with fairly conservative flying (some hovering), and using an APC 13 x 6.5E propeller (as PA states the VOXT40-X is on backorder). I bought two of the PA V2 Lipos @ $48 and 3 ofEPBuddy's Glacier Lipos @ $20 and I get about the same flight time from either. I also think the Glaciers come down cooler than the V2s do, however, the V2 are a bit lighter. I was able to achieve recommended CG with battery set alittle foward (about 1"), on the battery tray and found PAs recommended CG on the money.
