RE: 120 decreasing rpm
I just replaced all the regulator parts minus the body itself. I just adjusted the low end so that the screw was flush with the housing and got it running. It will rev up but will start to loose rpm pretty much right away and if I hold it at full throttle it will drop all the way down till it dies. It did this before I replaced the regulator parts. I currently have the high end at 1 1/2 turns out. Not sure where to try next?
thanks
Jeff
