RE: Bridi Great Escape Wing Dihedral Question
Thank you. I believe I have figured out the issue. The constuction notes have you turn the wing halves onto the designated "top" side and aligning them on a flat surface. Any gap in the wing halves on the bottom is what needs to be sanded at the top of the wing to create the proper dihedral, that is, 13/16ths TOTAL, NOT under both wing tips. This creates a flat wing on top with appropriate dihedral on the bottom. Thank heavens I read the construction notes!
If anyone would mind verifying my conclusion, I would appreciate.
Mike
