RE: Extreme Flight Vanquish 2m Build Thread
One of the things to consider in batteries if you are sport flying vs running a pattern sequence is your power on vs power off. Running a pattern sequence, you have many power off moments in 45, 60 and 90 degree downlines. In sport flying, you have the power on a lot more. Many of the more experienced pattern pilots have very good throttle management skills. Depending on the class flown and power management, I have seen a lot of guys drop down to 4200-4500 mah packs (still 10S) because with good throttle management they can get through the sequence. 4200-4500 mah packs also weigh less as well.
Once I was through the major trimming of the Vanquish and started to run some patterns, my flight time increased by 2 minutes. Between only using 3/4 throttle for up lines and and the power off down lines, that is how the extra 2 minutes was achieved.
