RE: Ultra Bandit instruction manual
Ragz,
You could contact the seller and ask him for the S/N, or provide the name of the seller to me in a PM as soon as possible.
By the way, if the airframe has a JetCat bypass tube and tailpipe installed, it will be a very tight fit, as the JetCat P-200 is 5.07" (128.8 mm) in diameter and 13.658" (346.17 mm) long.
The Olympus HP is 5.16" (131 mm) in diameter and 15.118" (384 mm) long, an increase of 2.2 mm in diameter, and and 37.8 mm over the P-200. The cooling airflow could become an issue.
I suggest removing the JetCat engine installation kit, selling it and install the Olympus kit P/N K7300-20.
I have no doubt that the Oly would perform better in the correct bypass tube.
