ORIGINAL: dsa0111
I have a jamming x1 crt and the stock engine...I believe is the OFNA hyper .28 big block...anyways last time I ran it it would just bog out the whole time and I noticed a gas leak...I took the body off and hit the gas and watched fuel fling out of where the clutch is...I'm not sure what to do or how to fix the issue I pulled the engine out and took the clutch cover off but that's as far as I've gotten..please help I can post pics on request
If you are sure that the fuel is coming from behind the flywheel, then it sounds like a bad front engine bearing. Not too hard to replace. But without some experience, it coud be dicey.
http://www.youtube.com/watch?v=iNnZa2k27lE
