RE: 120 decreasing rpm
Jeff,
I had a similar problem years ago, I fixed my engine by replacing the piston and ring, maybe the engine you are working on is just worn. By the way, my engine started to loose power in flight one day, and after three flights with the same problem I had to change the piston as I mentioned, it was something we will think it happens gradually, but no. And which 120?
Regards
