While the glue for the sheeting cured, I took a look at a hole in the sheeting that was closer to the wing root. I cleaned out the splintered pieces, gave it a simple shape and beveled the edges with a razor blade.
I used a piece of broken sheeting from the port wing to make the patch, and beveled the back edges.
Then it was just a matter of adding some glue and securing it in place while the glue cured.
Later, it will be sanded smooth.
