RE: 62
I don't have access to the camera.
It was a simple install. I simply enlarged the existing guide pin holes in the fuse to allow the incidence change. Then I installed some Gators in the fuse in the teardrop shaped hole just ahead of the rear pin. Carefully fill the corresponding hole in the wing with some ply and drill a hole to accept the adjuster pin.
The fuse doesn't allow much movement as the wing actually fits into the fuse but their was enough to get rid of all the aileron trim and much of the up elevator trim.
The plane flies much better now even though it still has some up elevator in it.
Hope this is helpful,
Rick
