RE: Piston Ring Question
The purpose of the pin in the groove IS TO PREVENT the ring from rotating in the groove and possibly catching/snagging a port. If it's running good than you should be OK and the ring is in proper alignment with the pin. I believe that OS engines have a smaller"sweetspot" where everything needs to be so all the pieces can slip into place, somedays you wish you had three hands.
