ORIGINAL: john_s3
I just though of some thing to check.I have both servo arms coming off the same side of the servo.Does one come off the left and the other right?? I will give that a try.
I have reread the manual 3 timed( The elevon and related sections).I will get this.it is not supposed to be this hard...LOL
Yes, you usually set them up like you would aileron servos. With the pushrods coming off opposite sides of the servo. That could very well be what is causing your confusion. Pull the servos out and "bench" them outside of the plane. Work the controls and see if they respond as they should.
Hope this helps
Ken
<br type="_moz" />
