RCU Forums - View Single Post - Another hinge question
Old 08-16-2012 | 06:38 AM
pigcop2's Avatar
pigcop2
Default Another hinge question
Good Morning,
I'm working on an Electricub by GP. It calls for ca hinges for elevator, rudder, and ailerons. I have read good and bad things about CA hinges. I was thinking of using a different kind.
My question is, can I use robart pin hinges? Or should I use a dubro flat pin hinge? The reason I ask is the wood I'm working with is only 3/16in thick. I was thinking of the 3/32 robart, but not sure if there is enough wood left over to hold the hinge in place without breaking out. I'm most likely not going to be doing a ton of acrobatics with this. Mostly scale flying.
John
