RE: NEW DLE 20cc Gasser! (Data & Links 1st Post)
Check your choke plate to see if it's really sealing the the carb throat properly. You may have to loosen the screw and let it recenter. While you're at it, seal up that hole in the choke plate. Solder works good, but there are other solutions as well. It doens't need to be there for our application. That done, then you should be drawing some fuel when the choke is closed....
