RE: Super Tigre G 90 Muffler: Lost front baffle
These mufflers do not come apart. You have to remove the baffle through the exhaust inlet using a stong pair of needle nose pliers. Grab the baffle and twist it out. If the baffle is not loose, you'll have to remove the rivet holding it.
