RCU Forums - View Single Post - Going to order Great Planes' Escapade this week.
Old 08-17-2012 | 10:37 AM
Thedrew
Default RE: Going to order Great Planes' Escapade this week.
I also have the tailwheel on order already. I've read up on a lot of the problems they have and plan on making a few modifications to it. Thanks for the advise, do you recommend I balance the CG at the recommended position, which I think is 2.5 in back from the leading edge at the fuselage sides, or farther forward?<div></div><div>Placed the order last night. It's going to arrive on Tuesday
Other mods I'm planning are
glueing tail assembly
Im not sure if they every fixed the problem with the elevator connecting rod so I'll wick some ca into it
Sealing control surface gaps (does this need to be done on both sides or just the top?)
mounting fuel tank upside down if necessary to align predrilled holes in firewall
Bracing and beefing up backet that holds main wing in place, along with any other weak spots
Some type of foam to seal gaps between wing and fuse
Possibly rubber wheels for the main gear (thoughts?)
I think I'm going to add a screw to the canopy through the bottom, this I won't be sure of until I can see what I'm working with.
Thats all I can remember for now. If I'm forgetting anything let me know!</div>
