RCU Forums - View Single Post - Going to order Great Planes' Escapade this week.
Old 08-17-2012 | 11:01 AM
markhamregular's Avatar
markhamregular
Default RE: Going to order Great Planes' Escapade this week.
<p class="MsoNormal" style="MARGIN: 0in 0in 10pt"><font face="Calibri" size="3">I did not do any of these things. The tail assembly takes 2 minutes to install. I did not glue mine and it’s still doing great. About the CG, what engine are you planning to install? With my OS46AX, the only thing I did differently was installing the battery on top of the fuel tank. There’s not much space inside the Escapade anyway to make any major change. With that configuration, it looks tail heavy based on the manufacturer’s manual. You can read the long thread about the Escapade. It’s longer than the hope of a poor man. Everyone complains about the wrong suggested CG.</font></p><p class="MsoNormal" style="MARGIN: 0in 0in 10pt"><font size="3"><font face="Calibri"><span style="mso-spacerun: yes"> </span>Expect the plane to land a little hot. The Escapade is not a trainer. When landing you will come hot and I only flair at the lasts seconds and in order to avoid bouncing I give a lot of elevator. Also, I have the Goldberg <span style="mso-spacerun: yes"> </span>tailwheel and it’s much higher than the one that comes with the plane. Upon landing sometimes the tail will start bouncing and bouncing but I have never had it nose down.</font></font></p>
