RCU Forums - View Single Post - Caldera 3.0 issues.....
Old 08-18-2012 | 08:34 PM
Dads like rc too
Default RE: Caldera 3.0 issues.....
ORIGINAL: terrywolfpack
Hello everyone i'm having issues with the caldera 3.0 brake set up??? When i start it up the break act like it doesn't want to work and i need a pic of the break setup if someone has it? and if there are any other problems with these caldera please let me know? just trying to fix for a friend...Terry
There could be a few issues. Is the throttle trim bumped up, this will affect your brakes. If that's good did you check the brake pad screws, these get loose from time to time. Then of course the linkage...has it been adjusted lately? Also the brake disc itself needs to be scuffed up with some heavy grit sandpaper occasionally.
