RCU Forums - View Single Post - servo on a float
Old 08-19-2012 | 06:35 AM
Ed_Moorman's Avatar
Ed_Moorman
Default RE: servo on a float
Bluebird standard size servos are waterproof. I have tested it.
I flipped a Neptune flying boat upside down and got the servos wet. I had a Hitech 425, standard size servo, and a Bluebird standard size (I forget the number) under water until the rescue boat could get out there. When I opened up the Hitech, it was full of water. The Bluebird was completely dry.
I happened to have another new Bluebird, still in the bubble pack. I opened it up, hooked it up to a receiver and battery and dunked it in a glass of water. I ran the servo back and forth for a couple of minutes, then checked it. Dry inside! I don't know about the smaller servos, but I use Bluebird standards on my .46-.61 sized seaplanes.
I also love Corrosion-X. I spray everything. Take the receiver case off and spray the PC board. Spray connectors and the switch.
Here's another trick. You know the bubble pack that covers spinners. It sort of looks like the rear part of a canopy. I use it to cover aileron servos on the bottom of the wing and on floats. See photo of read plane, a Danish HM-1 and on the blue floats.
I did kill a couple of servos flying early on from brackish water in a bayou here in the Florida panhandle. Now I use Corrosion-X, Bluebird servos and don't go near water with more that 0% salt. Salt water is bad, bad, bad.
ID:	1793264   Click image for larger version
