RE: PA Addiction X??
Next I decided to install the rudder. First gluing in the controle horn with epoxy. Rough up the center section with sandpaper before gluing in. Also make sure to glue it in square to the surface. Again, hinging was not as easy as expected. There are two smaller hinges with the ardware pack. These go on the rudder. Make sure not to use the larger ones where the smaller ones go. I aslo glued in the tailwheel at this time. Make sure you check you tailwheel before gluing it in. Mine was twisted just a bit so I had to straiten it before installing it into the rudder.
