RCU Forums - View Single Post - engine problem
Old 08-20-2012 | 11:56 AM
nitroexpress's Avatar
nitroexpress
Default RE: engine problem
ORIGINAL: Anthoop
ORIGINAL: nitroexpress
ORIGINAL: Anthoop
The front bearing does not seal the engine.
I call Shenanigans on this one.
I do not understand what you mean?
The post above mine implies that if fuel is leaking from the front bearing then the bearing/seal is at fault. I know that this is not necessarily true.
Please explain what you are saying?
I believe your statement "the front bearing does not seal the engine"is false.
Also, I believe DSA should elaborate on the statement "fuel flinging". Is it really gushing or just oozing. Alas, seems DSA has disappeared.
