RE: PA Addiction X??
Next I went ahead and got started on the wings. Again, hinging was a little more work. The pro kit came with the Hitec 82MG's. I needed to enlarge one of the servo bays just a tad. I also had to take just a little balsa top sheeting off where the rubber grommet for the servo sits on the carbon plate. Re-sealed around the servo bay. I pre-drilled the servo mounting holes with the Dubro center hole drilling tool that the instructions mention. After drilling and mounting the servo, take it back off and use some thin CA to set the threads in the carbon and re-install.
