RCU Forums - View Single Post - Pinch Test
Thread: Pinch Test
Old 08-21-2012 | 12:01 AM
1QwkSport2.5r's Avatar
1QwkSport2.5r
Default RE: Pinch Test
I set my needle with the tank half full, starting rich and pinch the fuel line and lean the needle until I get no rise in rpm. This way when the tank is full, the engine will run a little rich and as the tank runs down it will lean out. If you pinch and the engine cuts out its too lean, if it rises it's rich. No change is peak or very close to it.
