RE: Another hinge question
I built the same plane last winter. CA hinges are fine for that plane. It's a light weight plane which will not get allot of stess on the hinges.
I did go with a different brand of CA hinge, because I didn't like the ones that came with the kit. They were a plastic material with a plastic mesh on both sides. I test fit them and found them diffecult to shove into a tight slot, because the mesh would pull away from the plastic inner material. I think I used DuBro hinge material.
