RE: Pinch Test
Tank placement and unloading due to airspeed are of coarse important. I always try the nose up position, I has to be able to run straight up or you'll be in trouble (on an airplane at least). When the engine can run fine with the nose straight up it is usually rich enough for flight, and there is no need for any pinch test at all.
