RE: Should a beginner buy a sealing iron?
One more point...... a clothes iron is heavier and harder to control. You may dent the wood by making contact with the iron, and the covering will stick if you pressed it into the dent! You just need to be very even handed and try not to let the weight of the iron rest on the aircraft.
