RCU Forums - View Single Post - A123 Question
Old 08-23-2012 | 01:57 PM
  #56
HoundDog's Avatar
HoundDog
My Feedback: (49)
Default RE: A123 Question
ORIGINAL: RCP57
Finally getting back into the hobby after two years and the battery technology has changed quite a bit. What is the hot ticket for giant scale airplanes? Need to put some new batteries in my 35% YAK w/da 100 motor. The A123 batteries seem to be the newest technology but has anyone come up with a way to check them? Or do I need to look in another direction like Lithium Ion w/regulators?
<span style="font-family: Comic Sans MS;"><span style="color: rgb(128, 0, 0);">I fly with an Hitec Aroura 9 with 7 and 9 channel optima receivers ... the receiver continually displayes the onboard battery voltage and you can set a low limitt and then the transmitter moduel beeps and flashes the red light to warn me that the on board battery is at or below the limit Ihav set in the transmitter. The transmitter also records the lowest and highest battery voltage for each flight.</span></span> But I have switched to LIFE 2500 MAH 2 cell Zippy Bateries from Hobby King about $9.00 each.
