GYRO SWITCH
DAVID,
CAN'T YOU SWITCH THE GYRO OFF FROM AN AUX CHANNEL OR FROM A MIX?? THE GYRO'S I USE COME WITH A SWITCH THAT TURNS THE POWER OFF TO THE GYRO. YOU CAN PUT THE SWITCH TO AN AUX CHANNEL, OR MIX IT TO ANOTHER ACTIVATION POINT. I HAVE MY GYRO ON NOSE WHEEL STEERING ONLY, THE GYRO GOES OFF WHEN THE FLAPS ARE IN THE FULL UP POSITION. ROGER HAS HIS GYRO OFF WHEN THE GEAR IS UP POSITION. WORKS REAL GREAT. SOUNDS LIKE U MIGHT WANT TO JUST PUT IT ON AN AUX SWITCH & TURN IT ON & OFF WHEN U WANT.
SEE YOU THURSDAY!!
DAN M.
