ORIGINAL: gaRCfield
ORIGINAL: camaro101
ORIGINAL: gaRCfield
If you are serious about flying pattern, get a 2M plane. You already have a small pattern plane. If you get a 1.10 size, you will find yourself going to contests and dreaming about a 2M plane.
You can't go wrong with the Vanquish. The 2M Osiris might be out soon. Can't go wrong with the Monolog, either.
Haha in light of me misunderstanding the rules I was just going to look at a 110 wind haha until you posted this
I think. Your right though if I do get less then 2m I will be sitting around wishing I had a 2m
Hmmmmmmm I can't decide at all
Is there a build thread on a mono anywhere?
The Vanquish would probably run you the same amount of money, and give you more flexibility with setup and component choices.
Yea the vanquish is what I'm leaning towards
Should i do a himax in it?
I just hate the color scheme on the vanquish and the blue and pink one is not due in until october
I think that will most likely be the way i go
