RE: Alpha Trainer Problems
Glad to help. For a new engine, adjust the "slight rpm increase" with "significant rpm increase" and you'll do fine. Low end tuning on a new engine is pretty much the same, but it's a total waste of time trying to get a perfect idle mix when the engine is still too tight to idle right anyway. At whatever idle speed it will be reliable at though, the same set of tests apply.
