RCU Forums - View Single Post - Meister Scale Zero - step by step
Old 08-24-2012 | 02:26 AM
mirce
Default RE: Meister Scale Zero - step by step
After successful maiden flight with Meister P-47, I continued work on my Meister Zero. OK, I was working in meantime, but now I gonna give "full throttle" on this project...
On elevator I made ends from balsa, but in middle I put thin ply...
After sanding elevator was ready to set on the fuselage. Alignment was perfect...
Rudder also lay perfectly...
For the rear of the fuselage I bought plastic part...
It fit very nice, but weight is not small. I think that will sand it inside with my Proxon to reduce weight. Zero is short in front and every gram on the back of the model can made problem on CG.
I start working on other wing half...
Wing (even without wing tips) is very huge...
To be continued...
Mirce
