RE: Throttle servo buzzing for DLE20
Plus two,set your throttle up well mechanically with the servo end at it's innermost point on the arm and the throttle linkage at it's outermost point on the arm.If you can't get full throttle barrel movement then adjust from there.Trims/subtrims and expo are a last resort.
