RE: WACO YMF
On the actual subject of building PICA WACOs, I have must completed the kit a bought through RCUniverse a few months ago, and feel like showing it off a little. Following several suggestions posted in this thread, I made the horizontal stab adjustable and had landing gear struts fabricated from sheet aluminum, including an inner brace which is spring-loaded to absorb landing shocks. The plane is covered with 21st Century coverite and painted with water-based paints from Ace Hardware. The graphics were made by Cal-Grafx, and the whole plane is clear-coated with Ace gloss clear polyurethane. The plane is powered by a DLE 30 turning a 18x8 Zoar prop.
The plane has completed two flights, and after trimming, behaved very well. Although it turned out a little heavier than I had hoped, the DLE 30 provides plenty of power, and landings are very gentle, with virtually no bounce.
